Sketch 3 & 4 in Feature are in Red
Richard_Sicard
Member Posts: 6 PRO
Sketch 3 & 4 are red. I do not want to delete. Can the part be manufactured regardless?
NeilCooke
Moderator, Onshape Employees Posts: 6,076
Richard_Sicard said:
Hi Richard, did you toggle "share with support"? If you have created a ticket with support, they will deal with your query soon - if you want help on the forum you will have to make the document public, but make sure it is not proprietary because it could be copied without your knowledge.The document is toggle "share"I got a message from the software: " The sketch has no external reference." Can you explain this?
Most likely, the error message refers to a missing sketch plane - edit the sketch and check the dialog box. I agree with @bruce_williams - red is bad.
Senior Director, Technical Services, EMEA6
You may be successfully generate your down line geometry. However, the model will not be stable - Why are you not fixing the sketches? If you share the document others will help. See the post here.
