Sketch 3 & 4 in Feature are in Red
Richard_Sicard
Member Posts: 6 PRO
Sketch 3 & 4 are red. I do not want to delete. Can the part be manufactured regardless?
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,417Richard_Sicard said:The document is toggle "share"I got a message from the software: " The sketch has no external reference." Can you explain this?
Most likely, the error message refers to a missing sketch plane - edit the sketch and check the dialog box. I agree with @bruce_williams - red is bad.
Senior Director, Technical Services, EMEAI6
You may be successfully generate your down line geometry. However, the model will not be stable - Why are you not fixing the sketches? If you share the document others will help. See the post here.
