Problem with opLoft and qUnion([qNthElement(......query
tonvis
Member Posts: 41 ✭✭
Can someone of the team please help me out ?
Working on a Bevelgear FS combining Neil Cooke's Spurgear and ika Hölsö's FS , I got problems with opLoft to use two teethprofiles as edgequeries from qUnion([qNthElement( .......
Lofting whole sketches is no problem but I just need a cut-outpart of the sketches:
/* 687
var vertrices = qUnion([outer_modul, inner_modul]);
var profileSubqueries = [qCreatedBy(id + "sketch5"), qCreatedBy(id + "sketch6")];
opLoft(context, id + "loft1", { //@opLoft: LOFT_VERTEX_ADDITIONS error
"profileSubqueries" : profileSubqueries,
"vertrices" : vertrices
I has tried everything. It may be very simple but I can't find a solution.
When working in partstudio it is no problem to loft the both faces.
May thanks for your help
tonvis
I found the answer//******************************forming teeth *********************************************tonvis
/** to get the teeth_faces out of all other faces, this is the right way to do it
* use qSketchRegion(id) and qUnion([qNthElement(faces, n)])
* I was using edges first, but that was the wrong way of doing
* with no result
// -----------------solves all the faces to select from --------------------------
var faces = qUnion([qSketchRegion(id + "sketch5"), qSketchRegion(id + "sketch6")]);
//debug(context, faces); //debug: Query resolves to 2x6 faces
// ----------------- get the teeth_faces out of 6 faces -------------------------------
//var faceQuery0 = qUnion([qNthElement(faces, 0)]);
var faceQuery1 = qUnion([qNthElement(faces, 1)]); //2 x onder
//var faceQuery2 = qUnion([qNthElement(faces, 2)]);
//var faceQuery3 = qUnion([qNthElement(faces, 3)]);
var faceQuery4 = qUnion([qNthElement(faces, 4)]); //2 x boven
//var faceQuery5 = qUnion([qNthElement(faces, 5)]);
//debug(context, faceQuery1);
//debug(context, faceQuery4);
/** no problem for loft any longer ! it was really hard to find the solution */
"profileSubqueries" : [faceQuery1, faceQuery4]
1
You probably need to be more specific with your query: var profileSubqueries = [qCreatedBy(id + "sketch5"), qCreatedBy(id + "sketch6")];
Sketches have edges, faces, vertices, bodies - which ones are you lofting?Senior Director, Technical Services, EMEA0 -
Hello Neil,I am aware of your point but that is just my question . Featurescript is not simple to make the right queries.On the sketch picture you see the corresponding cut-out for teeth, but I can't get hold on these faces,edges or bodies to obtain a loftWhat query do I need ?Thanks for your quick reactiontonvis0
try:
var profileSubqueries = [qCreatedBy(id + "sketch5", EntityType.FACE), qCreatedBy(id + "sketch6", EntityType.FACE)];
Neil,Thanks for your answer.I had tried this before and then I got this total sketch , but I need only loft a vew parts out of it.
If I // --------------------------------- delete unused edges ------------------------------------------
opDeleteBodies(context, id + "deleteBodies1", {
"entities" : delete_edges
});All will disapear and I get @opLoft: LOFT_SELECT_PROFILES error.I hope that you help me out with a solution toget hold on :var outer_modul = qUnion([ // 2x bottom edges
edgeQuery_5,
edgeQuery_6,
edgeQuery_8,
edgeQuery_10
]);andvar inner_modul = qUnion([ // 2x top edgesedgeQuery_17,
edgeQuery_16,
edgeQuery_19,
edgeQuery_21
They won't listen to me !tonvis0 -
* with no result
1 -
@tonvis
It's not really a great idea to rely on qNthElement().
What I would do instead is something specific like:const face1 = qContainsPoint(qSketchRegion(id + "sketch5"), vector(1, 2, 3) * inch); const face2 = qContainsPoint(qSketchRegion(id + "sketch6"), vector(3, 2, 1) * inch);
Replacing the position with an actual position that you know exists on that sketch face.Jake Rosenfeld - Modeling Team0
