Dark Theme?
AZΘRÆNAZΘRÆN Member Posts: 22 ✭✭
Does Onshape have a dark theme?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,933 PRO
    Not natively, but it is run through a web browser. So you can modify css with some extensions.  @MBartlett21 could give you a link to one.. I forgot what it was..
  • AZΘRÆNAZΘRÆN Member Posts: 22 ✭✭
    I found a good one, Dark Reader is the name
  • colin_starker933colin_starker933 Member Posts: 16 EDU
    I used to use this, then it began to invert the colors of the rendered models, producing glaring white shadows. Do you have this problem? Did you switch to another plugin?
