Cannot see custom mates in assembly view
neil_clayton
neil_clayton Member Posts: 19 ✭✭
Happy new year :)
I'm confused!  Can't see custom mate connects from a PS within my assembly.
e.g: in the PS named "Power Base", I've three MC's defined (FN2070, Fan, Center of lower).  Yet these don't show up under the part witin the part studio.
What am I missing?  I see *other* MC's showing up from the same PS, but not these ones.
https://cad.onshape.com/documents/15e657b3c3df5f459a2b4376/w/76591c58cb2d7e4ef9abf235/e/f42c9a4b2b10ce730972a7ee
  • neil_clayton
    If I move the creation of the MC down in the PS feature list, it appears in the assembly.  Are MC's are only exposed in some circumstances?
  • neil_clayton
    Ah. I think I see. The new body would have the same name (depending on how the boolean op were configured), so I probably missed seeing that. The part was still in the tree; with same name, but it's actually a new part so old MC no longer owned by it. Makes sense. It'd be kinda nice if there was a "hey did you really mean to eat these MC's along the way" list, especially if they are defined and then not referenced by later features. But then; perhaps its plain better and more self-documenting if I just make sure to create my MC's designed for easy assembly at the end of my feature lists....  ta!
  • gary_owen
    gary_owen Member Posts: 5 ✭
    I have found another reason for this.  It is possible for the ower part to set as a plane rather than the solid.  I'm not sure how I managed that; possibly because the location geometry was set by a sketch.  Once, I changed the owner part to the solid, the mate connector appeared in the assembly.
