Im unable to select or delete named views
nicholas_witham
nicholas_witham Member Posts: 23 ✭✭
I have an arrangement that has/had 2 different named views, but I am unable to select them as I get an error code.
Im also unable to delete these named views.
As these named views seem to be broken, I created some new named views that do work.
The named views that don't work are the ones in upper case, and the named views that do work are sentence case.
Is there a way to delete these "broken" named views?
https://cad.onshape.com/documents/1d0adc94f0192fbb520130ba/w/80d0543ae61c2d6d8e387578/e/49fc6d2085cc63e7952519da
  • john_mcclary
    Which tab is this happening? I checked all your sub assemblies and part studios, all of them that have named views appear to be working for me.
    Have you tried clearing your browser cache?
  • nicholas_witham
    Its the "General Assembly"
  • john_mcclary
    I am not showing any named views in that assembly.
    So they are already deleted.
    Are you still seeing them?
  • john_mcclary
    again, try refreshing your cache.
    press F12 then right click your refresh button and select empty cache
  • nicholas_witham
    I've completed the refresh  process you note, but still have the same views available.
    Im surprised you can't see the same views I have
