Creating Multiple Lofts from Linear Pattern of Circle Sketches
sylvain_cornelus
Member Posts: 3 EDU
Hello,
I'm creating a practice 3D print for tapered heat set inserts to determine the right size. I'd like to create an array of lofts between various sized circles on a rectangular prism.
Here's my part: https://cad.onshape.com/documents/0fd63e74f8558ca407410cd8/w/150d7ed514b4c73afde5d7d4/e/c63e92e94cc05653e7b3026e
My two questions:
1) how can I create multiple lofts at once? (OnShape only seems to allow me to make one at a time and I can't pattern the feature after)
2) what is the best way to create an array of circles that increase in size by a certain amount at each location in the linear pattern or how can I ungroup them after patterning them to change each of their dimensions slightly
Any advice is much appreciated!
My two questions:
Here's how to do it with a linear increment:
https://cad.onshape.com/documents/508c9bf00f382b583a6bfca8/w/6d09f3056925703ec4445b99/e/3ecfed97de8a6ecdeb1376a8
If you want more control, you would have to do each one manually.Senior Director, Technical Services, EMEA8
If you want more control, you would have to do each one manually.Senior Director, Technical Services, EMEA8 -
You can only make one loft at a time. Patterning should work fine. You can't ungroup a pattern. This may be easier to do using an extrude with draft rather than loft.Senior Director, Technical Services, EMEA0
@NeilCooke Can you do an incremented pattern of a "scale uniformly" feature? I ask as in the part I've modeled the void for an insert as a solid body and then scaled it before removing it away from the target part by way of adjusting tolerance, but didn't think of the OP's idea of an incremented test piece.
HWM-Water Ltd0 -
@owen_sparks not sure I follow you, but any feature that can be driven by a variable can be incremented in a pattern. If you need any help let me know.
Senior Director, Technical Services, EMEA0 -
I opened this, and I see that it is adding 0.005 in on each subsequent loft. I can't for the life of me figure out how or why. What is being done in this part to allow that, and does it extend to features outside of loft?NeilCooke said:Here's how to do it with a linear increment:
If you want more control, you would have to do each one manually.0 -
See second video here: https://forum.onshape.com/discussion/2675/improvements-to-onshape-february-11th-2016/p1Senior Director, Technical Services, EMEA0
