Modeling curves
jean_daniel_lebon
Member Posts: 2 PRO
I want to model spark plug cables from the distributor cap of a mechanically timed electrical ignition system (Delco type) to their fixation points. In my specific application, all cables have the same length, and they shall be perpendicular to a defined plane at each entry point. How can this be modeled? Thanks.
Hello Jean Daniel. Would https://www.onshape.com/cad-blog/onshape-custom-feature-spotlight-wiring be of any use to you? - Scotty
Hi Scott, yes I saw this, it is interesting and would have served my purpose.However, I have one additional constraint. As I have mentioned, all cables shall have the same length from their starting points to the endpoints. With the method that you mentioned, the cable length is a result of the modeling process.I have 19 cables (all starting on the same vertical line at a certain spacing) to connect to 19 points distributed on 5 vertical lines (all endpoints being in the same vertical plane).I will make a sketch to make it clearer and will send it. Thanks.
