how to frame a rating. How to exclude hatching?
gérald_viotgérald_viot Member Posts: 5 EDU
Hello, I would like to know how to frame an absolute dimension to use with a position tolerance for exemple.
I would like to know if it is possible to remove the hatching from an axis cut perpendicularly and also on the cut ribs.
Thanks  (google translation)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    The answer is "no" to your other questions. Not hatching a rib is a big undertaking, not entirely sure I understand your other request.
