Quick "show" and "hide"
Brad_Goodman
Member Posts: 39 ✭✭
Quick way to easily "show" and "hide" parts - particularly in Part Studio.
Keyboard shortcuts would suffice. (Preferable)
Once of the biggest annoyances - is the fact that they "show part", "hide part", "hide 2 parts", "hide all parts" (etc.. etc...) menu options in the "parts" list are context sensitive. This means when you go to right click somewhere in the parts - you have to either stop and concider the context ("Is the part you just clicked selected or not?" or READ through the menu see what's present and what you want to select.
Alternativley you can right click on the part in the main window, but that is also context sensitive and even worse, in that the show/hide options either appear towards the top or the middle of the menu depending on what's selected.
Long story short - I usually/often want to "select - hide - select - hide - select - hide..." .... then maybe "show all". Fast. Rapid. No thinking...no reading...
Also check out this function's cousin, "Isolate" (Shift + I).
chadstoltzfus@premiercb.com
