Bad Geometry After Extrude
Any ideas what causes the extra surface? This is the first feature (sketch-extrude) in part studio. I have rebuild the sketch, still the same issue. Looks like corrupt data to me.
    NeilCooke Posts: 6,097 image
    Can you share the URL of the doc? It may be due to one or more of the vertices in your sketch not being aligned properly.
  • ThomasHertzler
    ThomasHertzler Posts: 4 ✭✭
    The problem started well into the project. Up to that point I have had no issues. First I recreated the geometry in the offending sketch, then I deleted the sketch and recreated the geometry. Switched browsers (New Edge - > Chrome) to avoid potential issues with browser cache. No joy. Deleted the part studio tab and started from new. Profit. I have moved on but if you want to analyse the issue further, look for where I delete the part studio (between V1 and V2)
    Link to document: https://cad.onshape.com/documents/11a9692e6af9b3b2d9eb1b5a/w/c4ab155169daf83d6af0510f/e/0434002f2be6e9b84bedb656
    Thanks for your help.
