Restoring a separate Part Studio?
mike_hölscher
mike_hölscher Member Posts: 110 ✭✭✭✭
Hi,
I have an Onshape Document with several Part Studio's, where I am working  on several parts in different Part Studios alternately.
I have made several Versions at specific concept states.
Now I would like to restore a specific Part Studio to a specific version, while keeping all the work done in the other Part Studios.
If I restore the complete Onshape Document my progress in the other Part Studios is lost, or the Part Studios created in between will not even be there anymore.
There is no way to do this right?
What is the best working method to avoid this situation in the future?
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,110 PRO
    Branch one of the versions you want to restore. Then merge it into your active branch
  • Than_Bogan
    Than_Bogan OS Professional Posts: 6 PRO
    I have this exact same need, and I'm afraid I don't understand your answer, @john_mcclary.  Could you or anyone else provide a little more detail?
  • raj_Onshape
    raj_Onshape Onshape Employees Posts: 113 image
    We don't have selective merge or restore yet.
    Until then you can open the version. Copy that version to a new document. Copy the part studio that you want and paste it in the original document. It would a copy so assemblies and drawings might need to be repaired with replace references
  • Than_Bogan
    Worked!  THANKS.
    I do think per-tab restores would be a nice feature, though.
  • Félix_Bouchard
    Félix_Bouchard Member Posts: 2 ✭
    Thanks!
    And I think it would be more than a nice feature,
    I think it makes the restore function  almost useless the way it is.
