Loft between part with inner loop
gauthier_östervall
Member Posts: 99 ✭✭
I have this part which is a frame, I am trying to create a loft with guides, from the part to the area of a sketch.
Apparently I'm not allowed to use a face with inner loop.
What should I do? I can see that I could make a filled part then Shell, but it fills a little hacky. Should I create surfaces separately?
Here is the project: https://cad.onshape.com/documents/fbd4e81d03f9c041891a1afd/w/dcd79ae0f0434dba47b87263/e/770cdc1a587f3685892dbd1a
Not sure what you mean by a root? Could you show a picture?
Perhaps you need to select both ends in shell feature.
@lana, thank you for understanding what I meant, not what I wrote
