Shell fails and I don't get why
gauthier_östervallgauthier_östervall Member Posts: 99 ✭✭
I have a fairly simple part, which I want to shell. 2 mm shell work, 3 mm and above does not.
What is it that prevents shelling? What can I do about it?
Project: https://cad.onshape.com/documents/fbd4e81d03f9c041891a1afd/w/dcd79ae0f0434dba47b87263/e/770cdc1a587f3685892dbd1a
    edited February 2020
    @gauthier_östervall
    Evidently you’re Bridging Curves 2 & 3 have too much of a curve on them for a shell of 3mm or more to work. I suppressed those two bridging curves and I was able to shell to whatever thickness I want.
  • timandrewstimandrews Member, Moderator, Onshape Employees Posts: 18 image
    @gauthier_östervall The issue is with Bridging curve 2 and Bridging curve 3. The shell fails because the sharp tangent curve shown below. If you change the second side end condition to "Match position" then the shell will work.
  • gauthier_östervallgauthier_östervall Member Posts: 99 ✭✭
    @timandrews @steve_shubin You got it, thanks!
