Default tangent lines setting in drawing template
etienne_houleetienne_houle Member Posts: 1
Hi,
I'm relatively unexperienced using Onshape.
I'm trying to create a drawing template into which the tangent edges are set at hidden and the hidden lines are set to show by default, but I havent found a way to do it.
I just found a way to change the thickness and color of theses lines in the template...
Would appreciate if someone could help me with this.
Thanks.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,041 PRO
    whatever you set up *should" stay with your template. But you will need to re-export/import the .dwt
  • KristianFKristianF Member Posts: 22 PRO
    There are no option to hide tangented lines under drawing properties.
    If you right click on view and make tangented lines hidden, this does not save to .dwt file (template file) when you re-export.
    So, what I have figured out, there are no way to save this to template.
