There is a problem while Drafting Exploded View.
vijay_vermavijay_verma Member Posts: 3 PRO
Hi,
There is a problem while drafting exploded view. After putting the view on the sheet and changing it into exploded view then its gone. it is not visible. but still the view (say isometric), is shown in the Design tree. I have done many things like changing sheet, reopen  my browser, make a new drawing sheet. but the problem is not solved.
Thank You
Aadi Swaroop
    Please open a support ticket using the ? menu inside Onshape. Thank you.
  • vijay_vermavijay_verma Member Posts: 3 PRO
    NeilCooke said:
    Please open a support ticket using the ? menu inside Onshape. Thank you. Thank you I have done and waiting for the reply from Onshape Team.
  • Sushil_SharmaSushil_Sharma Member Posts: 1
    Yes I am also facing this issue. If anyone have any solution please share.
    I have done what neil cooke said but problem is still on.
     please share your opinion.
    @Sushil_Sharma can you post the URL to your doc here so I can take a look?
