delays in deleting
digitalcarbondigitalcarbon Member Posts: 102 PRO
there seems to be a delay in deleting at times....note the image...
there were some major updates i did when opened, took several update all button pushes...maybe everything needs to catch up...
delays
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    Hey @digtalcarbon what are you trying to delete? The part you have selected in the screenshot you added?
    When you use the link document update button it sounds like you have a few layers of linked documents. Perhaps if you share an image of your instance list that would be helpful as well.
    If you submit a support ticket and share the document with support we can take a closer look.
    Twitter: @bradleysauln
  • digitalcarbondigitalcarbon Member Posts: 102 PRO
    what I found out is that i have to deselect everything then go the the feature list and select then delete...that works...so I think its not broken, its just i have to learn the steps
  • don_bdon_b Member Posts: 152 ✭✭
    Hopefully at some time in the future updates of context, will be automatic, like saves, and order of operation will not be so much of an issue
