Unable to extrude a surface
gerald_kreissiggerald_kreissig Member Posts: 8
I am following the tutorial “How to Build a Nut“ https://www.onshape.com/cad-blog/tech-tip-how-to-build-a-nut.
When it comes to create the thread, it says that I have to create a surface slightly larger than the corpse.
But in my case, I am not able to create the surface, because I cannot select any curve within my part.
https://cad.onshape.com/documents/5240649d84295c99acab56f6/w/00f8fd53fb2cf78022c7497b/e/c248a7ec08cca2c7549a464e
What am I missing? Any help is appreciate!
Best Regards, Gerald Kreissig
    edited March 2020
    Skizze 1 is hidden - press the eye icon to show it again -OR- you can just pick one of the solid edges to extrude.
  • gerald_kreissiggerald_kreissig Member Posts: 8
    That's the trick, I was missing!
    Thank you, Gerald
    Thank you, Gerald
