Creating plan in Feature Script
louis_rouquette622
Member Posts: 5 ✭
Hello,
I'm a beginner in the utilisation of feature script, and I was trying to create a plane.
But there is an error in my code but i don't understand where.
My code is mainly inspired by hexInfill, because my final objective is quite similar.
I can't visualize the HexPlane using the debug function.
Thanks a lot to everyone who is helping me
My code :
annotation { "Feature Type Name" : "Infill" }
export const hexinfill = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Body", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
definition.body is Query;
annotation { "Name" : "Side" }
isLength(definition.side, LENGTH_BOUNDS);
// On cherche les contours de l'objet
var Limits is Box3d = evBox3d(context, { "topology" : definition.body });
//var bbx1 = Limits.minCorner[0];
//var bby1 = Limits.minCorner[1];
var bbz1 = Limits.minCorner[2];
//var bbx2 = Limits.maxCorner[0];
//var bby2 = Limits.maxCorner[1];
//var bbz2 = Limits.maxCorner[2];
var Origin = vector([0, 0, bbz1])*meter;
var Normal = vector([0, 0, 1]);
var Xdir = vector([1, 0, 0]);
var HexPlane is Plane = plane(Origin, Normal, Xdir);
precondition
debug(context, HexPlane);
var HexSketch = newSketch(context, id + "sketch1", {
"sketchPlane" : HexPlane
skRectangle(HexSketch, "rectangle1", {
"firstCorner" : vector(0, 0) * inch,
"secondCorner" : vector(definition.side, definition.side) * inch
skSolve(HexSketch);
I believe your error is here:
There should be no square brackets - they indicate an array, not the values of a vector.Senior Director, Technical Services, EMEA0 -
Hi,Thank you very much for your reactivity.I have modify it, but nothing have changed, I still can't see the plan using the debug function.Moreover this part of the script was copied from the hexinfill featurescript, and it seems to work quite well.If someone have an other idea.0
"Limits" already has units of meter, so Origin turns it into meter^2
Change to:var Origin = vector(0 * meter, 0 * meter, bbz1);
Senior Director, Technical Services, EMEA1 -
@louis_rouquette622
In the top right corner of your screen there is a button that looks like "{✓}". If you click on that, the FeatureScript console will appear at the bottom of your screen. This will show you where the the code is failing. You can also use the "println" function in FeatureScript to print to this console, which makes debugging easier.
https://cad.onshape.com/FsDoc/library.html#println-
https://cad.onshape.com/documents/f1caabb4228cd8cb993f4d76/w/46e9322cd384d4d5d570985d/e/b5f747c7686bccbb2c96ec2d
Jake Rosenfeld - Modeling Team0 -
NeilCooke said:"Limits" already has units of meter, so Origin turns it into meter^2
Thanks a lot, it was that.
