Sheet metal bend WITHOUT sheet metal tool
kvdmolen
Member Posts: 26 ✭✭
Hello,
I have imported some existing (complex) 2D DXF files which contain the flat design of a sheet metal.
The actual product is bent over the line:
I can extrude the DXF drawing as a flat sheetmetal.
But how can I now bend the sheetmetal in 3D in Onshape?
I also tried to extrude separate parts (top of line and bottom) and transform them according to the bend-radius, but then I need to connect surfaces, which is also not possible?
Many thanks,
Klaas van der Molen
Many thanks,
Klaas van der Molen
@NeilCooke
You could also use my sheet metal fold feature:
http://onsha.pe/documents/9f116620b0f6d04445f57293
IR for AS/NZS 1100
