#newbie : how to modify a Cirlce to an Ellipse
Hi !
I'm banging my head against the wall because i can't do something that should be very simple ...
I want to modify a circle into an ellipse, keeping the most upper point fixed of the shape fixed; simply put, elongating the shape downwards.
I created 2 construction lines and added "contained" constraints to the circumference--- i can't seem to find the "circumference is a circle" constraint, so when I make the vertical line longer it makes it an ellipse.
Thank you for your help !
    You can’t make a circle into an ellipse. But you can make an ellipse into a circle - use the specific ellipse entity type, found in the drop down under the circle icon in sketch.
