How does one access a sub-assembly's Named Positions, or Display States?
StephenG
Member Posts: 385 ✭✭✭
I have a assembly of a mechanism with multiple "Named Positions" (plus Display States) that reflect relevant operational positions.
This assembly is inserted into another (higher level) assembly where I wish to see the mechanism's operational positions in the context of the higher lever assembly.
I do not see a mechanism by which I can reference (activate) the Named Positions or Display States that were created in the sub-assembly.
I am expecting to find this functionality in the Context Menu pop-up menu from a selected assembly instance.
2
I don't believe you can access display states of sub assemblies.
You may need to upgrade to configurations1 -
When Assembly Configuration functionality became available I immediately tried to create configurations to reference various Display States and Named Positions to represent mfg assembly/disassembly processes.
Unfortunately, Display States and Named Positions cannot be included in an assembly configuration.0 -
No, they are separate things.
You will need to create the positions by manipulating mates.0 -
To get the functionality I want it appears I need to create configurations in the instanced (sub-)assembly with various mate parameters that reflect the positional states I want shown in a next/higher level assembly, even though there are Named positions defined in the instanced assembly that reflects the positional state I want to shown.
Just in case someone else is trying to find the answer to this...
Apparently around July of 2022 this function was added. This improvement request was marked complete. The what's new and the change log don't make it clear that this functionality was added. At the time it focused on adding views to drawings of named positions.
Anyway, in a higher level assembly, right click on the lower assembly, and select "Add to named position". This will allow you to use named positions of subassemblies in higher assembly named positions. The UI is similar to how configurations can trickle down.
I'm very happy to discover that this exists. It is in the help.
1
