Blank parts in sketches
When I want to make a blank part in a sketch (let's say I want to draw a washer—a solid circle with a smaller blank concentric circle) it sometimes just makes the part I want blank solid. It appears to decide at random whether or not I deserve a blank area in my sketch. I usually just leave it to chance and work around it but there must be a way. Anyone know?
Many thanks,
Bart
Many thanks,
Bart
Check out the training videos on sketching, they explain this issue well
Thanks! I think I already knew this but I haven't used Onshape for a while so perhaps I was just frustrated.
Thanks for your help
Bart
In the exacting language of geometry, as used in solid modelling, a circle is a single, infinitely thin line.
Extruding a circle would produce a surface, not a solid body.
I think 3dcad meant the area bounded by the outer circle only, in other words, something which would extrude as a disk rather than an annulus.
