Move Context Origin
dt_userdt_user Member Posts: 8 PRO
When creating a part in context, the I am prompted to set an origin for the part studio to be created. How can I change this origin location once the context is already created?
    You can’t, that’s why it asks you to define it in the assembly first. The origin is really only a reference location - you could create a point or a mate connector to become your new origin.
  • tom_augertom_auger Member Posts: 129 ✭✭
    I did this - created a mate connector on the reference part, created the in-context part, but later I modified the original context and updated it, but the origin didn't move to match the new position of the mate connector so the whole model is broken - what did I miss?
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 152 PRO
    I had the same as the above here. Set a mate in the assembly for origin of a new part studio, realsied later I should have flipped the origin of said mate. Flipped it in the assembly, none of the changes propagate to the part studio, and no ability to update the context.
    Context assembly primary instance is not set. Finish inserting part or set primary instance of context before updating the assembly context.
    The solution seemed to be that once I start inserting parts from the created context into the assembly, then updates happen.
