part transparency look
dan_schniersdan_schniers Member Posts: 16 ✭✭
is there a way of making the transparency look of the less so they will show up better and not so light
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,063 PRO
    There is no setting you can change. If you want more control of the transparent amount. You should create an improvement requests on tme right - - - >
