Sheet Metal "internal flanges" for gluing?
chad_etzel
Member Posts: 4 ✭
in General
I have been using the Sheet Metal feature with great success to create some prototypes with cardboard by laser cutting the flat pattern. Currently I am fixing the sides by running hot glue down the seams of the walls, but I am hoping it is possible to add "internal flanges" like you see on papercraft templates, such as this cube. The "flanges" below are meant for gluing the sides together after you cut it out and fold it.
I have tried using the flange feature, but it (probably correctly) prevents me from adding flanges on the inside edge of a model.
Is this possible to achieve with the current sheet metal features? (I'm also not sure what to call these "internal flanges" if they have a proper name)
Link to example document: https://cad.onshape.com/documents/6be4e3c2fd06d227c1ee0e79/v/a07d5c03b913e0c836ad9471/e/53f2523241152804df37e858
john_mcclary
Member, Developers Posts: 3,996 PRO
Thre flange feature should work. You may need to pre-notch near the inside corners. Or use mbartlett's shaped flange feature.
https://cad.onshape.com/documents/602655eff016f183fc184978/w/c20bffc426bdb249281c9a38/e/2b68c88d6cff8044631d941d
5
