Center of a square in iPadOS
@mrlefebvre101
Here is a workaround that you could do in the Part Studio. You could open up that part in the assembly and the Mate Connectors will be there
5
Unfortunately those mate connector inferences are not yet available in the mobile apps.In the mean time, you can mate the corner or edge of your part to the corner or edge of the hole.0
@mrlefebvre101
5 -
@steve_shubin Thank you! This worked. I need to practice with it a bit, but it's a pretty efficient workaround.
@mrlefebvre101It’s good to hear it worked
OK I edited this text below —
The initial focal point of the zoom is where I initially place my finger. The rate and amount of zoom is finger pressure related.
You can pan a bit while you’re zooming in if you move your finger left or right. You can also change the focal point while zooming in if you move your finger up or down. But if you apply too much finger pressure, it’s going to zoom in so fast that you aren’t going to be able to pan much at all
When you lift your finger away from the screen, it automatically zooms back out
As wordy as this above explanation is, if you just play with it for a while, you get the hang of it real fast
