text above dimension line
douglas_downiedouglas_downie Member Posts: 3 EDU
Hi,
 Is there any way of changing the dimension lines in the drawing so that the text is above the line and not through it. This is British Standards and I'm not sure if this is possible. New user so steep learning curve. Thanks in advance.
Douglas
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,953 image
    You must choose (or create) an ISO standard drawing sheet
  • douglas_downiedouglas_downie Member Posts: 3 EDU
    Thanks.
