Making drawings only
tahir_jauhar597tahir_jauhar597 Member Posts: 2 EDU
If it is possible to make to-scale drawings only without making the part model in onshape.
What features I can generate the 2D drawings of any component without having to make 3D model for it. Meaning I don't have a 3D model or don't understand making one.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,043 PRO
    edited May 2020
    Yes, Similar to autoCAD's model/paperspace logic. I'll try and use AutoCAD terminology to help make the connections.
    You will draw your 2D drawing in a partStudio sketch. (Model Space/viewport)
    Then in the Drawing tab (Paper Space) you can insert the 2D sketch and dimension it.
