Comparing enum check inside group
MBagwan
Member Posts: 15 ✭
Hi @NeilCooke
Inside the group, I am not able to compare enums.
suppose I have variable group.type which of one enum ok. Now I want to compare this enum value and depend on this value need to declare some specific annotations and ignore other annotations.
But I am getting error like this, " Could not Identify Parameter Id in either operand of comparison in if".
Could you just explain what I am doing wrong?
Can you share your code here? Just need the precondition.Senior Director, Technical Services, EMEA0
Hi, Thanks for the quick reply, here is the code.export enum ENUM_TYPES{annotation { "Name" : "TYPE_1" }TYPE_1,annotation { "Name" : "TYPE_2" }TYPE_2}annotation { "Feature Type Name" : "feature name" }export const featureName = defineFeature(function(context is Context, id is Id, definition is map)precondition{// annotation { "Name" : "Enum Type" }// definition.enumType is ENUM_TYPES;
annotation { "Name" : "enumType", "Item name" : "entities", "Item label template" : "#enumType" }definition.groups is array;for (var groups in definition.groups){annotation { "Name" : "Enum Type" }groups.enumType is ENUM_TYPES;if (groups.enumType == ENUM_TYPES.TYPE_1){}if (groups.enumType == ENUM_TYPES.TYPE_2){}}}{if (definition.enumType == ENUM_TYPES.TYPE_1){//call type 1 method}if (definition.enumType == ENUM_TYPES.TYPE_2){//call type 2 method}});0 -
Sorry - now I understand your question - it does not work with "Array Parameters" at this time. There is a ticket open for this already - if you would like your name added to it, please vote here: https://forum.onshape.com/discussion/7628/conditional-visibility-of-array-parameters/p1Senior Director, Technical Services, EMEA1
