Drawing to CAD Model
abhinabha_baratabhinabha_barat Member Posts: 5 EDU
I have created a 4 view model in a Drawing. Is there a way to move 1 of the drawing to a part studio so that I can make it bigger and view it from different angles??
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,063 PRO
    You should be starting with a 3d model in a partstudio, then insert that into a drawing. Not the other way around.
    You can change the size by adjusting the scales of the view and drawing sheet.
    Double click the view to change scale. And right click the sheet and go to sheet properties to change sheet scale.
    You can show non-ortho / iso views by saving a view position in the part studio, then select that as the view in drawings
