CAD .Please give me the solution if possible.
zahirzahir Member Posts: 6
Design a pair of mating herringbone gears having a gear ratio 2.5.
Use suitable dimensions of gear and apply fillets and chamfers
where required. **Constrain the motion of gear (i.e. on rotation of
one gear, other should also rotate.
    edited May 2020
    Everything you want to do has been addressed in pieces on the forum. Try searching for help on "helical gear". Also look up the tutorials on CAD fundamentals and mating, including the gear mate. FYI people on the forum are happy to help, but we don't typically just design things for you from scratch. If you've tried to help yourself and have run into a roadblock, we're happy to help with specific questions (vs. "here, do this design for me for free"). Also, you should check out the forum post checklist. Cheers!
