how can I change the diameter of a solid
zahirzahir Member Posts: 6
    @zahir
    Your question is too vague for us to help for sure. That said, changes are one of the strengths of parametric history based CAD.  Your image is of the Part Studio where the gear was designed. You may change the original sketch or Move face or Extrude Add or Remove to name a few ways.
    www.accuratepattern.com
    Looks like it was imported. You can use Transform/Scale or Move Face.
