Angled Section View Control
shawnrwshawnrw Member Posts: 50 PRO
Hello,
Is there any way to precisely control the angle of a section view? +1 one again on having sketch driven dimensions in drawings to do..
  • shawnrwshawnrw Member Posts: 50 PRO
    To provide further context, I need to control the angel for which the section is at to add dimensions on additional drilled holes that are off-center.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    If that is a part not an assembly, then you can show sketches from the partstudio. Make a sketch with a line representing the cross section you want. Then snap the cross section line to that
