Making Connections
nishayla_coxnishayla_cox Member Posts: 2 EDU
If I want to find a part to connect with the one I finished previously, where do I search on Onshape?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,055 PRO
    In an assembly tab, open the insert dialog. You can press i to open if with a keyboard shortcut.
    If your part is in the same document. Then you will see it listed here. Click on the part and click the green checkbox on the top right.
    If it is not there then click the 'other document' button on the top middle. Find your part by clicking my onshape, or recent
