Help Configuring Faces
Cache_River_Mill
Member Posts: 225 PRO
Hello,
When a color is configured with a face, all of the configuration inputs are placed into columns. Is there a way to delete the unwanted configured columns? Or perhaps a way to configure a color in the standard configuration panel?
The way it is configured now, I can't configure colors unless the stars align with all of the different configured variables... Perhaps I am doing it wrong?
No, you are doing it right. Properties are config-specific so you do have to align all the stars. A wilcard option would be good.
@Evan_Reese 's FS could be easily extended to allow face colors.
Senior Director, Technical Services, EMEA5 -
I actually made that update a few days ago. It works with faces now.NeilCooke said:No, you are doing it right. Properties are config-specific so you do have to align all the stars. A wilcard option would be good.
@Evan_Reese 's FS could be easily extended to allow face colors.1
Thank you for the quick reply. Excellent, the new updates are fantastic by the way, thank you.
@Evan_Reese 's FS could be easily extended to allow face colors.1 -
Not only can I color a part face with this, but this lets me color a face and then over ride that color by coloring the face again if the conditions require it! Wow. @Evan_Reese
pretty cool! credit for that goes to the Onshape devs. All I did was add a line to allow faces and they made it work.cache_river_millworks said:Not only can I color a part face with this, but this lets me color a face and then over ride that color by coloring the face again if the conditions require it! Wow. @Evan_Reese1
