help needed
mathew_tolsonmathew_tolson Member Posts: 2
Hello. Im trying to print my drawing onto an A3 piece of paper at 1:1 scale but im finding its running over the boarders when i print. Im not sure how to do this. I want to turn 2d into a print then cut out and justify it.
Cheers Mat
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    edited June 2020
    First, check the Forum Post Checklist. Specifically, it's hard to troubleshoot a document if you don't provide a link. That said, this seems more like a general printing problem, not an Onshape issue. Make sure your drawing template size either matches or is smaller than the A3 paper you're printing on. For example, doing a 1:1 print of an A2 drawing on A1 will definitely result in printing past the paper edge. Next, make sure you're printing at 100% scale. This will be in the print dialog or printer preferences.
