Hole callout: allow both countersink and counterbore
jason_atwood316jason_atwood316 Member Posts: 5
edited August 2020 in Using Onshape
I'm creating a part which has a hole which has both a countersink and a counterbore. Looking at the hole callout tool I can only pick one or the other. Ideally I should be able to pick both.
    @jason_atwood316 Can you provide an example?  Are you wanting to have it add a chamfer to the edge of a counterbore or something else?  Picking a cbore on entry and a countersink on exit?  Examples will help scope this.
  • peter_searspeter_sears Member Posts: 2
    An example I have is the need for a counterbored hole (to minimise the length of the fastener required) with a countersink at the bottom of the counterbore (because common wood screws have countersink heads).
    I also like the idea of being able to add chamfers to holes, but that's another story (and another level of complexity)
    Newbie to OnShape here, loving the power (but still getting used to it!)
  • glen_dewsburyglen_dewsbury Member Posts: 1,299 PRO
    A reasonable way I can see to make a recessed wood screw hole is with 2 steps. Extrude a hole then use the bottom for the hole function.
    edited March 2025
    @lougallo
    Hey Lou. I can see a very good use for the form tool on non sheet metal parts as well.
    I noticed form tool works fine with just the remove selection. Sure looks like something that went around a few years ago as an IR. Maybe under the heading of 'blocks'? With configuration many things will work like the original screw hole or in this sample maybe bearing mounts.
    Peter. This would cover the chamfers when needed.
    https://cad.onshape.com/documents/1d35f627efed69ade1b185a2/w/3713e0d14bfcfe62f90cebb8/e/64cc9735b859384b784dda4a
  • jelte_steur_infojelte_steur_info Member Posts: 653 PRO
    edited March 2025
    Another option that i use sometimes is to start with a countersink hole and add a move face (translations) afterwards… (saves you from manually determing the right diameter for the extruded hole mentioned above.
    Works fine for 3D, i don't believe a call-out on a drawing will be accurate though…
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,086 PRO
    This type of hole is specialized and should probably have a cross section with full dims on the 2D, IMO, rather than a shortened callout.
