is it possible to create a balloon inspection report as it is done in solidworks?
jason_shepardjason_shepard Member Posts: 2 PRO
I have a customer that requires a balloon inspection report as it is done in solidworks.
is this possible in onshape
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    Hi @jason_shepard - no, it's not possible to create an automated inspection report as in SOLIDWORKS Inspection (which is a paid-for add-in by the way), but you can balloon the drawing manually using callouts and build the inspection report in a spreadsheet. More work, obviously - if this is something that you will need to do often, can you create (or vote on) an improvement request in the category on the right --->
