blue line that can't be hidden - it's not a sketch (all are on hide mode) and i can't select it.
asaf_chertkoffasaf_chertkoff Member Posts: 2 EDU
it's just sitting there...
i tried to roll back and find when i've created it but even if i go to the start of the action's tree it is still there.
Please, H-E-L-P!!..
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Can you make the doc public so we can take a look? If you make a copy of the doc I suspect it will go away.
  • alnisalnis Member, Developers Posts: 452 EDU
    I think I've seen this problem before. If you refresh your browser, it goes away (at least when I've had it happen to me).
  • Matt_LoMatt_Lo Member, Moderator, Onshape Employees Posts: 15 image
    Clearing your local browser cache or a hard refresh (shift + reload button) should clear this line.
  • Skr3pSkr3p Member Posts: 4
    This worked for me.  Thank you, I was about to go crazy!
  • justin_cooper343justin_cooper343 Member Posts: 2
    Awesome! This has been bugging me of late! So simple!
  • CloudCloud Member Posts: 3 EDU
    I was about to make a new post about this so I'm glad someone else did a while ago. Does anyone know why this happened? I think it happens when I use the Use tool most often but I don't think it's exclusive and it definitely doesn't happen all the time. I also notice that the points on the line do correspond to geometry in my model, but the color is distinct from any other feature in the app. That makes me think it's in some way intentional but I just don't know how I'm causing it to happen.
