Driving the design by a table
rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
Hi, so far I have been creating a feature script defining global variables say lx, ly lz to use as driving dimensions.
I wonder if configurations could be useful to create a more userfriendy way for a 3rd user to insert custom dimensions.
Basically a table in this format:
Name    |   Value
lx           |   12
ly           |   23
lz           |   42
where the numbers could be directly editable.
I can not find out how to setup configurations to do that if possible.
Any help appreciated
    Hi @rune_thorsen229 - Are you trying to create pre-defined sets of lx, ly, and lz such that the user can select a configuration and all three options will update simultaneously?
    The easiest approach would be to just create three variables for lx, ly, and lz and each one can be updated independently. If, you then want to save specific combinations of values for quick regeneration, you can create a list driven configuration. Then, for each list item, you can set appropriate values of lx, ly, and lz.
    In the example below, the three variables control the length of the sides of the block. The three configurations change the values of the variables.
    NOTE: This only works within a single part studio. If you really need a configuration table for your "global" variables to drive multiple part studios, I'm not sure there's a way to do that.
  • EvanReeseEvanReese Member, Mentor Posts: 2,824 PRO
    You would also consider using the configuration variable instead of the list type
  • paul_rippingalepaul_rippingale Member Posts: 1 EDU
    https://learn.onshape.com/learn/video/advanced-configurations
    This webinar explains it fully, I've repeat watched this several times, made notes and I had a go which came out successful, very pleased with myself.
  • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
    Thanks paul_rippingale, at minute 38 thats exactly what I wanted. By the way, what is the use of TEXT variable? I cant seem to use it withing the Part Studios > Sketch Tools > Text
