cannot remove material with extrude removal
I am new so this may not be the best approach, I am trying to remove a section of a revolve with an extrude.
It shows in red exactly what I want to happen but it cannot complete it.
What do I need to do to fix this?
The part is at https://cad.onshape.com/documents/0239a3f19d0701eaa0da5a3d/w/313b596e0462aedec3b36103/e/a55f728ee6ee060241bc9301
If you change extrude2 to 'new' then your cut will work.
then 'boolean' your parts back together at the end.
https://cad.onshape.com/documents/0992349e334511ad6523036e/w/31192c8b3ca7a273db60432f/e/447138b13994c0159ec3e5cb
