Simple + and - in an equation. Why doesn't this work?
todd_hammer272todd_hammer272 Member Posts: 2
I'm trying to use a simple + in a dimension equation and its not working.
I've set a variable #thickness
My simple equation I'm putting in a dimension:   #thickness+.03
The following works:  #thickness/2
+  and - doesn't seem to work.
What am I doing wrong?
Thanks in advance.
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    Interesting. I just tired the function out and NO it doesn't work.
    #x+#y works but #x+1 gives an error.
    That was unexpected. Been using calculated dimensions a fair bit but only with variables.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Values have units so all terms in an equation must be of the same type such as length.
    @glen_dewsbury
    @todd_hammer272
    If you use #thickness + .03mm and give the 0.03 value units, it will work.
    IR for AS/NZS 1100
    Thanks.
    Just checked what happens when "number" is used for variable instead of "length" and the problem goes away.
    Current system units are placed for the whole result. #X+1 becomes (#X+1)mm in a dimension.
    @glen_dewsbury
    I find that having units helps me get correct logic...
    IR for AS/NZS 1100
  • brian_bradybrian_brady Member, Developers Posts: 505 EDU
    You can also do this; make your variables unitless. Then you can use (#x + 1) mm or (#x + 1) inch
  • on_sema2on_sema2 Member Posts: 2 PRO
    Hello all,
    Don't you know if its possible to use parameters as part of equation for another parameter?
    Example:
    @on_sema2 remove the =
