Does anyone have a dodecahedron tutorial or can comment on techniques to make one?
Anyone have any good methods for creating a 12 sided dodecahedron in on shape? Has anyone made one successfully? I saw two tutorials for other cad programs but no examples in on shape for making this geometric shape. I found this one: http://www.inventortales.com/2012/11/all-for-fun-again-modeling-12-sided-die.html and also this one from solid works http://learnsolidworks.com/solidworks_tutorials/how-to-model-a-dodecahedron-in-solidworks.
Any help would be grateful!! Thank you so much!
Dan
Dan
nav Member Posts: 258 ✭✭✭✭
Hi @daniel_hoffacker here a link with my approach, to be honest I used the following Solid Edge video as reference and did the same but with the tools available in OS.
Here is the public URL:
https://cad.onshape.com/documents/b86179670fa44e5f8b21b133/w/c1850f8e165a449a8120ed4a/e/88488bdabd954d66bf9b57f1
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions8 -
lougallo Member, Moderator, Onshape Employees, Developers Posts: 1,995
@nav Awesome!! I copied your start of sketches (the hardest part) and simplified a bit.
Doc link: https://cad.onshape.com/documents/a6f9725433784b5ba56affb1/w/574d0540967243e0b7a2febd/e/d1bf3b4566e34f69966f0d08
You can thicken sketches... so no need to do lofts and once you have half, you can mirror and transform 36 degrees. Fun exercise...Lou Gallo / PD/UX - Support - Community / Onshape, Inc.7
If I have time in weekend, I will give it a try.
https://forum.onshape.com/discussion/comment/7053#Comment_7053
(somewhere along the way, the endpoint of Sketch 4 in Lou's model has lost what I infer was its pierce relation to sketch 3, BTW)
Just did a version in the public Doc I shared above using Extrude and it works as well
Thanks for your typically thorough and thoughful message. I was able to add a pierce constraint no problem between the endpoint of the line and the circle from sketch 3, BTW, and that fully constrained that endpoint.
Pierce relation does indeed capture the point where a curve passes through the sketch plane. Give it a go!
The view below represents the top view, side view and front view (all orthogonal, no tricks) showing all visible edges and contours of a single body.
What does the isometric view look like?
(To anyone who has already encountered this one: it would be nice to hold off any spoiler posts until someone has solved it from scratch)
That was a fun exercise. I'll admit to overthinking it quite a bit on my first stab. The isometric view should look like this:
https://cad.onshape.com/documents/be38bd57d9c94b8ebe63c5a3/w/bb52af5f6b6d429f91dccdcb/e/1f4e140d4fb749b3b5eb52b4
No one has emailed me saying they were able to do it in less, so i would go with my solution
(and I win the whole internet)
Again - congratulations Jon.
(link redacted because it pointed to an internal server - i will post it when @jon_sorrells recreates it on production!!!!
https://cad.onshape.com/documents/e24d1462c393404888cee882/w/173143f610874497b0482b22/e/4c785c6c51d948a487b97c32
Does that mean you have to give the internet back?
https://cad.onshape.com/documents/9d0cf267925b4d55860e528d/w/27869f5acf6d49ce967b429d/e/0ee54e01680346dfbce11720
I imported a finished dodecahedron as a cheat to avoid have to construct my sketch geometry from scratch: hence the two "Fixed" points in Sketch 1, which started life as vertices of the finished solid.
It would be a trivial exercise for a Platonic geometer to do sketch 1 the proper way... and (unrelated point) I have an inkling there's the potential to save at least one more step.
the first two sketches are easy for the revised method: it was staring me in the face
The first key is to draw sketch 2 before sketch 1, and draw both the inner and outer pentagons on the base plane as in Philip's posted sketch. The second key is to align one of the pentagon edges, on that base plane (from either pentagon, it's immaterial which) parallel with a construction plane (the Right plane in this example). This will ensure that horizontal line in sketch 2, which serves as the axis for the first"Transform-Rotate" operation, is parallel to one of those edges, in which case that single "Transform-Rotate" is sufficient and the second can be eliminated.
The angle line in what has become sketch 2 is now drawn from the base circle of the larger pentagon, not from a vertex or midpoint of an edge.
A horizontal line whose midpoint lies above the origin, at the height of the dodecahedron, serves as a proxy for the upper base circle, which the angled line needs to pass tangent to. The sole purpose of the angled line is to position the tip of the loft.
The attached graphic might clarify this a bit. The upper circle is an extra sketch for explanatory purposes only:
In the model, it is represented (as mentioned above) by a horizontal line in the existing sketch on the "Right" plane.
OK, so the bar is now set at two (relatively simple) sketches and three (very simple) features.
I look forward eagerly to seeing the bar set higher still.
The document should open now from the original link (I set sharing on the wrong one)
But I'm puzzled why the graphic I attached to my llatest post has become detached. Here it is again:
Yay! At this rate, we'll be into negative feature count territory early next week....
My enhanced method would have two sketches and three features (the one I posted had 2/4)
It's not clear to me exactly how you're counting, because @jon_sorrells' previous effort was 2/5 by my count, yet you imply that nine would be an improvement?
Using your accounting method, that would put Jon's new solution at 5
If you also have a '5' solution please post it.
I apologize for casting aspersions, but a more cynical person than I, might look at your previous solution and suggest that you could not have developed that sketch without first having built the model, referenced the geometry and then deleted it!
Under the glare of a bright light, would you care to comment?
