Split and recombine surface?
tom_auger
Member Posts: 129 ✭✭
Oh boy, I'm trying something a little different. Trying to create this "ruff" like surface where the inner part is actually a loft created from two differently-sized circles, making it impossible to create the shape I want using a simple extrude or even a draft. I was hoping to be able to somehow intersect the "ruff" surface with this lofted surface and then recombine, but can't for the life of me figure out what tool(s) would make this possible.
A screenshot is worth 1000 bad descriptions, so here's a screenshot. Any advice (or follow-up questions in case I haven't explained myself) is welcomed and appreciated!
The grey surface is the loft. The "ruff" surface is blue. Similarly to the way the outside is connected only every other edge, I want to do the same on the inside.
Thanks in advance!
Thanks in advance!
John_P_Desilets
Onshape Employees, csevp Posts: 261
@tom_auger
Thanks for sharing Tom. Do you have a link to the Document so we can take a closer look?
Whenever working with patterns or parts with symmetry, try to produce only one feature and pattern that feature afterwards. In this example, you could probably get away with just a single tooth that is patterned after all features have been created.
5
John thank you so much for the lightning-fast response, as well as the most excellent advice.
Indeed, patterning has proved to be the solution here, but if I had started with that in mind as you suggested, I might have approached it even more efficiently.
In the end, I re-lofted into a solid and used boolean subtract first. Then I was able to loft two edges to "join" them and then repeated that feature in a circular pattern! Brilliant!
Thank you so much.
Happy to hear it worked out for you. Keep the good stuff coming.
