MB/h
NeilCooke
Moderator, Onshape Employees Posts: 5,952
No, because it all depends on the size of the model. Data is used the most when a document is first loaded. Making changes to a design does not use much at all. I have successfully used Onshape on flights many times, however the inherent latency in those connections can make the experience a little laggy.Senior Director, Technical Services, EMEA5
