Simple Math with Variables
romeograham
romeograham Member, csevp Posts: 783 PRO
I am trying to use a Feature Studio to set up project variables - to be used in a single Document.
I have, say, two specifications (Hmax & Hmin). I can set up Variables (setVariable) no problem.
setVariable(context, "Hmax", 30 * millimeter);
setVariable(context, "Hmin", 28 * millimeter);
setVariable(context, "Hrange" = (Hmax - Hmin)); /*how do I do math in this variable?*/
Now, I'd like to make a new "Hrange" Variable, that does a little simple math with those two variables:
However, this expression doesn't work. I tried a few different ways to do it, but even this simple thing is beyond my understanding. I'm not sure what search terms will help in the Documentation - haven't had luck with the searches that made sense to me.
Any help would be great!
Thanks
Romeo
  • _anton
    _anton Member, Onshape Employees Posts: 555 image
    The setVariable calls store a variable value in the context. You can use getVariable to retrieve the values. E.g.,
    const Hmax = getVariable(context, "Hmax");
    const Hmin = getVariable(context, "Hmin");
    setVariable(context, "Hrange", Hmax - Hmin);
  • romeograham
    Ah - so I need to tell FS that my previously-declared Variable is a Constant (const) that can be used in downstream calculations...something like that?
    Thanks for the quick help @_anton !
  • _anton
    So the getVariable call just returns the value (or throws, if it's not defined - see here). You could also write
    setVariable(context, "Hrange", getVariable(context, "Hmax") - getVariable(context, "Hmin"));
  • romeograham
    I think I like that better - I can keep the entire definition of the setVariable "Hrange" on one line.
    Or just define them all as variables at the top of the code, then you can do all the calculations you like before calling setVariable at the end. More code, but easier to read.
  • romeograham
    @NeilCooke
    I thought that's how I started out, but wasn't successful.
    Can you paste a little example here?
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,279 image
    edited September 2020
    I would actually do them in a map, something like:
    var v = {};
    v.Hmax = 30 * millimeter;
    v.Hmin = 28 * millimeter;
    v.Hrange = v.Hmax - v.Hmin;
    for (var entry in v)
        setVariable(context, entry.key, entry.value);
    var v = {};
    That's what I was going to put (honestly)  :p
    And save yourself some typing by putting at the top
    const mm = millimeter;
  • romeograham
    Thanks @NeilCooke and @ilya_baran - that mapping seems to be a tidy way to do it.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,102 PRO
    Seems like I've been doing this the wordy way. Thanks, @ilya_baran for the for loop solution instead.
