How do I use the centroid as a vector?
MichaelPascoe
Member Posts: 2,959 PRO
I found the centroid of my sketch with this:
The hint says it returns a vector, but when I try to use the variable "centroid" as a position in my sketch point, it says it's not a vector. and throws this error: Precondition of skPoint failed (value.position is undefined || is2dPoint(value.position))
Code for my sketch point:
Once the point is placed, how would I query the point so that I could use it in a loft?
var centroid = evApproximateCentroid(context, { //Finds the centroid of the selected face.
"entities" : definition.selectedFace
});The hint says it returns a vector, but when I try to use the variable "centroid" as a position in my sketch point, it says it's not a vector. and throws this error: Precondition of skPoint failed (value.position is undefined || is2dPoint(value.position))
var pt = skPoint(sketch, "point1", { "position" : centroid}); Once the point is placed, how would I query the point so that I could use it in a loft?
centroid is 3d vector while for sketch point you need 2d, so you need to transform it like that: centroid2d = worldToPlane(skPlane)*centroid
6 -
is realPlane2 a query or a Plane?
You will need to do evPlane to get the plane object for the plane query.6
6 -
I tried this:
var centroid2d = worldToPlane(realPlane2, centroid);
realPlane2 is the plane my sketch is on.
I'm still failing to implement it correctly. It throws this: Call worldToPlane(Query (map), Vector (array)) does not match worldToPlane(Plane, ...)
▚▞▚▞▚▞▚▞▚0 -
You will need to do evPlane to get the plane object for the plane query.6 -
▚▞▚▞▚▞▚▞▚0
