Sheet Metal Jog
matthew_stacymatthew_stacy Member Posts: 489 PRO
Has anyone got tips, tricks, tools, or perhaps a feature script to create a jog in sheet metal?  I'd love to see an example or two of how folks have attacked this in the past.
  • Cary_BettenhausenCary_Bettenhausen Member Posts: 45 PRO
    Bump... I am also interested in this functionality.
  • Andrew_MichellAndrew_Michell Member Posts: 6 PRO
    mee too
  • glen_dewsburyglen_dewsbury Member Posts: 1,056 PRO
    @matthew_stacy Here is a couple samples that I just made for a similar question using a sm extrude with adjustment to get the height corrected.
    https://cad.onshape.com/documents/fd8d60e9de614fef424c4257/w/f74808f6a3a75c2ab5c832d6/e/ca3ea29c67e222cf9d89f47a
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    @glen_dewsbury, thanks for the response.  Extruding the jog profile to create sheet metal looks like a viable approach, particularly for cases where the jog extends across the full width of the part.
    Any ideas for more general cases, for jogging one, or more, tabs of lesser width?
    I would like to see a parametric "jog feature", with fundamental parameters perhaps including offset and angle.  In this example I've created a folder for two unique jogs, each comprised of a pair of flange features.  The length of the first flange is derived from the specified offset value divided by the sign of the angle (add an optional correction of one thickness, depending on the direction of the initial sheet metal feature.
    @matthew_stacy
    I'm working on something a little more generic using configurations but it's not going very quick at this time. This would be a good candidate for feature script in the future.
    A jog feature in OS  basic sheet metal tools would be real nice.
    Working on making this one look nice as well. I used it a lot in lighting industry for installing covers. Only one side of cover needs a screw (sometimes no screw). Single hit punch and form.
