Removing instances from any pattern in Onshape
oscar_zapata
Member Posts: 2 EDU
in General
Hello everyone, just wondering if it's possible to remove an instance when creating a pattern on Onshape. For example, suppose I am creating a rectangular pattern of 20 holes but I don't want "certain" holes while doing the operation. In other CAD systems the center position of each hole could be removed by just clicking the unwanted holes. Best regards.
1
Also, there is a featurescript called Point Pattern that may be helpful in conjunction with a sketch pattern - https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/v/401953fe6e5330bb77bf28ef/e/268a22f0ce6b3864a3637732
You can also follow up your pattern with a "delete face" on the faces of the holes you don't want. This should restore the geometry to how it was before.
https://cad.onshape.com/help/Content/deleteface.htm
